Engine/Trans assembly swap
Ok, enough of the fvckery. I don't usually take Wiki's word for it, but here, click the link and scroll down to the 7th gen cars and take a look at the engines available. There is NO reason why this motor will not work in your car. Heck, I could put it in my 00 GT if I wanted to. In fact I'll be likely installing an 07 Buick Lucerne motor in the near future. Just using my wiring harness and whatnot.
Pontiac Grand Prix - Wikipedia
I have personally done hundreds of swaps, take what I say as the word of actual honest 3800 dedicated experience or not it's all fine in my eyes.
3.8L engines are 231 ci. All of them. The Grand National to the LN3's to the C motor to the Series I when the first SC'd one was introduced in the H/G body cars to the Series II that finally landed in the W bodies as well. There is only one cam in any of these motors and it's driven by a chain off the crank gear. 96-most 04 L67's had a steel oil pan from the factory in the W bodies. H/G bodies started to see aluminum pans in 2000. Oil adapters changed based on the year and body of the car. Sensors/TB's changed a little over the years, however when you look at these motors in a whole, it is easy to interchange them.
When you get a JY motor typically it will not have the ps pump, AC or alternator on it. The wiring harness is typically cut and the same with hoses. When I receive a motor, I "prep" the engine by removing all these things. Then I sit the two engines side by side and swap any brackets or sensors that are different. Now you new engine is ready to get dropped into your car.
Often the Hollander exchange (program that tells a JY what fits and doesn't) will say an engine won't fit based on a small bracket that you can change in less than a minute. Would you choose not to use a 20K motor for $300 in lieu of a 130K motor for $700 based on something as easy as replacing the alternator bracket with the one from your vehicle and $6 worth of coolant elbows?
You can use the lower end of an NA motor for an SC car.
You can use the 04+ L32 in an older L67 car by simply swapping intake manifold up.
You can use any NA motor in any NA car if you swap the upper intake manifold up.
If you look in the how to section you will find that many people have used the newer parts on older cars to not only get less miles, but also better things like the structural aluminum oil pan that doesn't leak like the steel one. All these things I am mentioning require no pcm programming. They are simply replacing parts.
For approximately 10 years I worked on almost nothing besides a GM 3.8L, my mechanic buddy would call me and ask why a 98 NA motor that was always $200-$300 was suddenly $600 with super high miles. I'd advise him to buy an 06+ lucerne 3.8L with 15K miles for $150-$250 and swap the intake/TB, and alternator bracket. His additional labor and gasket cost was less than $30 to use a better engine and have a happier customer due to lower cost and newer parts.
Short version: Here on this forum you are talking to people that have intimate knowledge and experience of the GM 3.8L platform specifically. A person working at a yard gets questions on tons of different cars a day, they do not specialize. You choose who you would like to believe, people that have done it and are talking from actual experience or guys looking at an interchange book?
I never thought it wouldn't work but Im not always right even though that's what I tell the old lady haha so I wanted to check with the professionals on here before I go wasting mine time and money and anyone elses time. im going to be doing this swap in about 2 weeks will keep everyone updated on how it went. thank you very much to everyone who took the time to give me all this information it is very much appreciated! thanks again and talk to you fellas in a couple weeks
!!UPDATE!! Got the engine and trans assembly out of the 05 grand prix took it out the bottom with subframe wheels and all. Inspected engine for leaks found crank seal leaking when looking up timing cover gasket kit the part numbers are different from the 05 to the 06 and the 05 part number says (without sleeve N seal:oil pan gasket required. Can anyone enlighten me as to why these part numbers are different and all that good stuff? Motor/Trans assembly is coming out of my 06 in 2 weeks apparently just waiting for shop space to open back up. Thanks in advance
Should have mentioned the 05 part number says 97-05 only the 06 part number says 06-08 only. Looks to me like there are some extra seals in the 05 kit. Thanks
i DIDNT Read the thread so forgive me if i am mistaken. Being you have a doner car The swap will and can be done. If the fail is going to happen it will be in the computer So just swap those too and you should be home free.
