Engine torque noise
kosmotion
2001 GTP 192k - I have a knocking noise when I accelerate and the same noise as I let off the pedal. I thought for sure it was motor mounts but I have replaced both trans mount and lower mount and no change. The dog bones appear to be in good condition. I have also just replaced the transmission. Any ideas?
The noise isn't related to rpm, it's more like how a wooden floor would creak as you apply your weight and then creak again as you unweight it.
I had a friend put the e brake on, his left foot on the brake and put in drive and pulse the throttle. I can observe the engine rock back under the torque load, then after it returns to idle the engine slowly rocks forward again I can hear the slow creaking sound. I have ruled out the motor mounts as they are both new.
