engine knocking
98bdgtp
Hey everybody I need some help with my car...well to begin a couple of days ago the engine started rattling well I found out it was the pulley of the AC compressor I was planning on changing the bearings but today as I was driving to work the whole car started shaking and as I pulled up to a stop sign I pressed on the gas but it didn't wanna go it was going real slow I pulled up to my friends house to check it but it wouldn't turn on anymore .......any help would be greatly appreciated thanks
does it crank but not start?
do you know if you had any knock (kr) when you were last running it really hard?
we really can't tell anything unless you give us more information.
Well the belts r good I replaced them about 2 months ago and the engine does crank but it doesn't turn on and the flexplate I don't know which one that is and I don't have the machine to check for kr
Well what's a spun bearing? Um I'm still learning evetthing of the motor and the parts so if yall can bear with me on that id really appreciate it and the oils good I changed it about 2 months ago
wow it could really be ALOT of things, if you need the car fixed now, just have a machanic look at it quick ($80) not cheap, or maybe someone on here that knows alot lives around there.
