I'm not aware that they changed year to year but they are surely different from 2005-2006 and 2007-2008.
The 2005-2006's use a E40 computer with a different cam/crank trigger than the 2007-2008's that run a E67 computer with the newer 58/4x trigger pattern. The engine and transmission harnesses are different because of that.
Related question, or maybe not. I have a crapload of codes. Most of them are O2 sensors, but some I've never seen before--C3064, C2174, C342D. I look these up and I get all kinds of different answers as to what they are. Is it possible these are related to the wiring harness being bad, or do I just have sensors committing hara kiri all at the same time throughout the engine bay?
as for the years, being short/special production there were likely lots of running changes to the harness' 05 didnt get the charging current sensor, 06+ did, harness now has new part number, 3 wires, 1 sensor, new part number.
when GM figured out that they could use much thinner/cheaper 22 gauge wire for their engine bays (without impacting the 60k warranty with corrosion issues/etc....who cares about what it'll do when at 150k and 15 salty winters later....) they changed the harness part numbers, even though the wire routing/etc was the exact same. it was just cheaper to make.
cars that experience harness chaffing issues will sometimes be wrapped differently/longer wires/additional mounting clips. new part number.
only way yer gonna know for sure is to look at the diagrams
So is there an actual part called a CAN bus, or is that just the name for the effect of all the computers tied together? And how do I diagnose and narrow it down? I don't want to just throw parts at it.
