digitalgpbandit
Member
I’m having an issue with my ‘99 Grand Prix to where it’s getting to the point of overheating when I have the ac on while either stopped or idling or at low speed driving. I initially thought it was the water pump until today it started happening. I pulled over in a church parking lot popped the hood and noticed only the driver side fan running. It didn’t even seem to be going full speed either. This was with the ac on and the temp gauge 3/4 of the way up. Both fans should have been running full speed. I shut it down and let it cool off for a bit. Started driving again, but left the ac off. Made it home and the gauge never went over half way. I popped the hood with it still running when I got home and noticed both fans were running now.
I am a bit nervous now with this 90 degree weather. I do have safeguards (if you call them that) such as a 180 degree tstat and dhp pcm which turns on the fans at the lower temp and keeps them running low speed for a minute after engine shut down. I also did a coolant flush about two months ago on it.
Are there any known issues with the engine fans I should be looking out for? What would cause only 1 to run?
