Engine bay fastener specs (l36)
Thompsju
Banned
So in the process of rebuilding my entire engine bay, I made the mistake of just tossing everything into a pile.
Upon reassembly, I smashed my head into the wall over and over trying to find the right replacements.
(thanks GM for making the 3800 a hybrid of metrics and standards)
I could not find this type of listing ANYWHERE online, only the torque specs for each bolt.
So I have begun compiling spreadsheets for the next guy.
Your input is requested at this point. I want to itemize every single fastener under the hood. (unless something like this already exists?
I will keep this post updated with all information until we as a community have decided it is complete.
Please, only submit EXACT measurements. Don't guesstimate what you think the gauge, length, thread, or type is.
Please submit your info in the following format.
Application. Measurements. Fastener Type (Bolt, Stud, etc.). #Required. Suggested Compound, Torque.
Example.
Lower Intake Manifold. 5/16" x 1 1/4". Flange Bolt. Required: 12. Thread Sealer. 15 Nm (11 ft. lbs.)
Obviously this will be cleaner on a final document. Any suggestions are welcome.
Stolen from wbodystore.com.
I'll remove them as they're applied.
TORQUE SPECS FOR 1997 - 2003 Grand Prix
Accelerator Control Cable Bracket Bolt 16 Nm (12 ft. lbs.)
Balance Shaft Driven Gear Bolt 22 + 70?Nm (16 + 70?ft. lbs.)
Balance Shaft Retainer Bolt 30 Nm (22 ft. lbs.)
Camshaft Position Sensor Bolt 10 Nm (89 inch lbs.)
Camshaft Sprocket Bolt 100 + 90?Nm (74 + 90?ft. lbs.)
Camshaft Thrust Plate Bolt 15 Nm (11 ft. lbs.)
Canister Purge Solenoid Valve Bracket Bolt (VIN K) 50 Nm (37 ft. lbs.)
Canister Purge Vacuum Switch Bolt (VIN K) 50 Nm (37 ft. lbs.)
Connecting Rod Cap Bolt 27 + 50?Nm (20 + 50?ft. lbs.)
Crankshaft Balancer Bolt 150 + 76?Nm (111 + 76?ft. lbs.)
Crankshaft Main Bearing Cap Bolt 40 + 110?Nm (30 + 110?ft. lbs.)
Crankshaft Main Bearing Cap Bolt (Side) 15 + 45?Nm (11 + 45?ft. lbs.)
Crankshaft Position Sensor Stud 30 Nm (22 ft. lbs.)
Crankshaft Rear Oil Seal Housing Bolt 15 + 50?Nm + (11 + 50?ft. lbs.)
Cylinder Head Bolt 50 + 120?Nm (37 + 120?ft. lbs.)
Drive Belt Tensioner Bracket Bolt/Nut 50 Nm (37 ft. lbs.)
Drive Belt Tensioner Bracket Stud 6 Nm (53 inch lbs.)
EGR Valve Adapter Bolt 50 Nm (37 ft. lbs.)
EGR Valve Inlet Pipe Bolt 29 Nm (21 ft. lbs.)
EGR Valve Nut 29 Nm (21 ft. lbs.)
EGR Valve Outlet Pipe Bolt/Nut 29 Nm (21 ft. lbs.)
Engine Block Coolant Drain Plug (VIN 1) 18 Nm (13 ft. lbs.)
Engine Block Coolant Drain Plug (VIN K) 30 Nm (22 ft. lbs.)
Engine Block Oil Gallery Plug 30 Nm (22 ft. lbs.)
Engine Coolant Temperature Sensor 25 Nm (18 ft. lbs.)
Engine Flywheel Bolt 15 + 50?Nm (11 + 50?ft. lbs.)
Engine Front Cover Bolt/Stud 20 + 40?Nm (15 + 40?ft. lbs.)
Engine Lift Bracket Bolt/Nut/Stud 30 Nm (22 ft. lbs.)
Engine Mount Nut, Lower 78 Nm (58 ft. lbs.)
Engine Mount Nut, Upper 78 Nm (58 ft. lbs.)
Engine Oil Pressure Indicator Switch 16 Nm (12 ft. lbs.)
Exhaust Crossover Heat Shield Nut 20 Nm (15 ft. lbs.)
Exhaust Crossover Pipe Bolt/Stud 20 Nm (15 ft. lbs.)
Exhaust Manifold Bolt/Nut 30 Nm (22 ft. lbs.)
Exhaust Manifold Heat Shield Nut 20 Nm (15 ft. lbs.)
Exhaust Manifold Stud (Inner) 30 Nm (22 ft. lbs.)
Exhaust Manifold Stud (Outer) 10 Nm (89 inch lbs.)
Fuel Injector Rail Nut 10 Nm (89 inch lbs.)
Fuel Injector Rail Stud 25 Nm (18 ft. lbs.)
Fuel Injector Sight Shield Bracket Nut 30 Nm (22 ft. lbs.)
Generator Brace Bracket Bolt 50 Nm (37 ft. lbs.)
Heated Oxygen Sensor 42 Nm (31 ft. lbs.)
ICM Bolt (VIN 1) 30 Nm (22 ft. lbs.)
ICM Nut 50 Nm (37 ft. lbs.)
ICM Stud (VIN K) 6 Nm (53 inch lbs.)
ICM Wiring Harness Bolt 2 Nm (18 inch lbs.)
Idler Pulley Bolt 50 Nm (37 ft. lbs.)
Idler Pulley Bracket Bolt 30 Nm (22 ft. lbs.)
MAP Sensor Bolt (VIN 1) 3 Nm (27 inch lbs.)
MAP Sensor Bracket Bolt (VIN 1) 30 Nm (22 ft. lbs.)
Oil Cooler Adapter Connector 50 Nm (37 ft. lbs.)
Oil Filter 30 Nm (22 ft. lbs.)
Oil Filter Adapter Bolt 15 + 50?Nm (11 + 50?ft. lbs.)
Oil Level Indicator Switch 20 Nm (15 ft. lbs.)
Oil Level Indicator Tube Nut 19 Nm (14 ft. lbs.)
Oil Pan Bolt 14 Nm (125 inch lbs.)
Oil Pan Drain Plug 30 Nm (22 ft. lbs.)
Oil Pump Cover Screw 11 Nm (98 inch lbs.)
Oil Pump Screen Bolt 15 Nm (11 ft. lbs.)
Power Brake Booster Heat Shield Nut 20 Nm (15 ft. lbs.)
Spark Plug 27 Nm (20 ft. lbs.)
Starter Motor Heat Shield Bolt 30 Nm (22 ft. lbs.)
Supercharger Bolt/Stud (VIN 1) 23 Nm (17 ft. lbs.)
Supercharger Bypass Valve and Fuel Pressure Regulator Valve Harness Bolt (VIN 1) 10 Nm (89 inch lbs.)
Supercharger Bypass Valve Nut (VIN 1) 8 Nm (71 inch lbs.)
Throttle Body Nut 10 Nm (89 inch lbs.)
Throttle Body Support Bolt (VIN K) 10 Nm (89 inch lbs.)
Timing Chain Dampener Bolt 22 Nm (16 ft. lbs.)
Upper Intake Manifold Bolt (VIN K) 10 Nm (89 inch lbs.)
Valve Lifter Guide Retainer Bolt 30 Nm (22 ft. lbs.)
Valve Rocker Arm Bolt 15 + 90?Nm (11 + 90?ft. lbs.)
Valve Rocker Arm Cover Bolt 10 Nm (89 inch lbs.)
Water Outlet Bolt 27 Nm (20 ft. lbs.)
Water Pump Bolt 15 + 80?Nm (11 + 80?ft. lbs.)
Water Pump Pulley Bolt 13 Nm (116 inch lbs.)
Wiring Harness Shield Bolt/Nut 10 Nm (89 inch lbs.)
FRONT BRAKES:
Bleeder Valve
13 N?m 115 lb in
Brake Hose Bolt
54 N?m 40 lb ft
Caliper Bolts
85 N?m 63 lb ft
Caliper Bracket Bolts
185 N?m 137 lb ft
REAR BRAKES:
Bleeder Valve
11 N?m 97 lb in
Brake Hose Bolt
44 N?m 32 lb ft
Caliper Bolts
43 N?m 32 lb ft
125 N?m 92 lb ft
Rotor/J 37160-A Nut
34 N?m 25 lb ft
That includes 2 of the 6 specs I called for.
And that's head sizes. So then it has 1 thing...
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Yes, the one thing I'm referring to.
Anyways, if you're not going to contribute, please don't flood the thread with garbage. Thanks. =)
Nice idea here. I wouldn't confuse a fastener spec thread with torque specs though. Plus, your LIM spec is out of date. GM updated as they changed the gasket a couple of times.
If you have bolts that you need to know where they go. Please post a picture and toss numbers next to types of bolts.
