Emergency brake light always on
99gtpguy
I bought a 99 GTP from the original owner about a month ago. It has 110000 on it. I noticed that starting last week, the emergency brake light comes on and stays on most of the time while driving. I have made sure the pedal is fully released. The brake still works fine when I need it. Anyone have this problem? Solution? Thanks in advance!
Fluid looks a little low. A little below the mid-line of the reservoir. The max line looks to be at about 3/4 full. I am going to pick some up tomorrow and hopefully that'll fix it!
You probably need to check your brake pads while you are at it. Pads getting low will be the main cause for fluid being low, unless there is a leak of course.
