Electronics/Google Gurus step in!
TyroElite
I'm looking for a source for these AMP/Tyco Electronics parts. Any of them will do. I've found a few places that will ship me only 20 of them (as opposed to spools of 30000+) but most of them have a minimum order of at least $30. I only need 20 of them or so which usually is about $.15/ea for a total of $3.00. Anybody have any good sources for this stuff?
173633-1
173633-2
175029-1
175029-2
173633-3
175029-3
173645-1
173645-2
175030-1
175030-2
173645-3
175030-3
175207-1
175208-1
345210-1
345212-1
yea, mouser doesn't carry these. That was the first place I looked. I just ordered some other pins from them a few weeks back and it went great. I'm bummed they don't have these.
Hmmm, I looked at newark but apparently, I missed the 1 part number they cary that doesn't require thousands be ordered at once!! Thanks again Toasty. The one they have is for 24-22 awg wire and I was hoping to find some for 18-22awg. Any other good sources??
the 2nd part number is the same gauge wire, just uses a different contact material... the first is brass and the 2nd is phosphor bronze.
Don't see any of them on the second site you listed.
I'm trying to match up a connector that is already there. I have otherways of doing it but I was trying to find a way to make it plug and play.
could you possibly use the one terminal that i found, and make it work with the slightly larger gauge wire? (crimp as well as possible, and use a little dab of solder to secure it?)
i'm just VERY surpised to see a tyco connector inside a GM vehicle... it is stamped tyco, right?
no tyco stamp but I looked up the part number from the connector diagram and that's what I came up with.
I think I will try using the small one that you found since its all I've got. Its the HUD control signal wires so I could probably use a small gauge wire and be OK.
I like doing things the right way even if it is a a little more work. If the tabs I find don't work out, I'll probably go with just finding some other 5 or 6 pin connector and use that instead.
can you post up the connector diagram you've got?
i suppose there's a first for everything, but i have NEVER seen a tyco connector in a gm car....
