Electrically Stumped
davis
Just joined site and need a little help. Wife comes home a month ago says, "abs light is on". We bought our GP new in 2000, so I get to looking around and find the abs ignition a/c clutch fuse blown under hood #28 I believe 10 amp. I replace it and start to back out and it blows again, needless to say it blows when it wants and i cannot duplicate when it blows. I have gone through a s load of fuses now. Symptoms abs light on, track light button will not do anything and a/c will not blow cold and power steering is a bit stiff, when you replace that little 10 amp fuse all is well. When I took it to the stealership and had the codes read, "it was replace both front hubs," done deal fuse keeps popping. Thanks for the help.:th_thumbsup-wink:
check the wires that go to the abs sensors, they may be shorting out, they run along the lower control arm, and clip on the new hubs you just got installed.
