Electrical question
stealth71
I want to hook up a dash cam. The one I bought has a standard cigarette/accessory style plug, but I want to hardwire it to a switched circuit. Can I use a fuse tap to wire it in, and if so, which fuse would be the best one to tap in to? I've read a few posts where members suggest the sunroof, however I don't have one on my car. Thanks!
I forgot to mention this is a 2006 Grand Prix. Is that power drop available for that year? If so, that looks like the way to go? I see three or four leads. One of those is a switched lead?
Oh, um... Can't say for sure on the '06. Best bet is to look behind/under the glove box. If it's there, you should see it right away.
3 leads. According to the website, one is constant 12v, one is 12v with key on, and one is ground. I know for sure one is keyed 12v power and one is ground, cause that's what I used. :D
