My car started running like crap again out of nowhere. First I noticed the loss of power then noticed high knock and misfires again. Then it just got weird. My gauges started to go crazy cutting off and on then the power to the gauges stopped and then came back on. The abs, traction, security, and all the rest of the warnings kept going off. It started making a horrible noise so I pulled over and opened the hood to see what it was. Everything was turning on and off. The throttle body was making noises, the relays for everything was activating on and off. The car died and will not start back up. But the weird thing, all the relays, throttle body and tests kept running even with the keys out of the ignition. The battery is newer and has no corrosion. All the grounds are good.
Could this be the ECM??? Or the BCM???? I have the battery completely unhooked right not to try and reset everything. Any suggestions. I'm stuck in a cvs parking lot now.
