A2tripp
99 gtp, n* setup, cam, zzp canned tune, rebuilt motor with 30k
i got a theory I wanted to run by the forum
im getting an occasional po507 (high idle) and an occasional fluttering of rpm on a part cruise throttle above 45-50 mph. The cel comes on usually after driving and at idle.
cars idles around a 900-1000 at park and around 750 in drive
i put on new vac lines about 3k ago/month I get a shakey needle from 14-15 bars at idle sometimes drops to 13.
i put a hose up to the ear and the only hear a hiss under the throttle body and the egr tube at the egr housing. When I spray around there I don't get a increase in idle so much but I can see it sucking in the spray from the egr tube at the egr housing. Egr tubes are new but were installed by po.
so I was thinking my egr tube to the throttle body could have a leak, BUT wouldn't that cause a leak only when the egr is open? The car has always idle around 900-1000 rpm, but after driving it and idling I have seen it 1100-12000 rpm.
thanks
thanks
