ECU Problem, Emissions can't scan my car, Error shows up on their scanner
JonnyGrandPrix
My question is, why my ecu cannot be read my emissions testing etc. Everything in my car runs fun, EVERYTHING, but when it comes to it being read by emissions and what not, it wont read correctly? Why is that?
Re: ECU Problem
do they plug it into the obd2 port? If so your fuse maybe blown its the same fuse for the cig lighter.
Re: ECU Problem
yeah they do and it comes up as a like an error or they cannot read it, and its weird because everything in my car works fine
Re: ECU Problem
there's a blue wire hanging near the port that looks to be either cut or ripped off, could that be the cause of an error reading?
Re: ECU Problem
Not sure what that blue wire goes to but it can't hurt anything to hook it back up and see if it makes any difference.
if your cigg lighter works, then its not the fuse.
fuse would be in the fuse panel in car. check your owners manual.
yes. hook up that blue wire that is ripped/cut.. or post a pic.. taht is likely the issue.
