Fun question, heres an extremely simplified explanation...
Gasoline contains 46.4 MJ/kg of energy, methanol is 19.7 MJ/kg, ethanol is 30MJ/kg. Lets remember e85 is 85% ethanol and 15% gasoline, so e85 would be (.85*30+.15*46.4)=32.46 MJ/kg. Lets also assume 20% of your fueling with the 93/meth combo comes from the meth, so on an energy basis, 93/meth energy content is (.2*19.7+.8*46.4)= 41.06 MJ/kg.
Already something should be obvious....you can make the most power, energy wise, on pump 93! e85 only has 84% of the energy content of straight 93 and 93/meth is only slightly better at 88%. This is of course ignoring the effect of detonation. Also dont forget this is based purely on just burning the fuel, not necessarily how much the engine can utilize of that (which is where timing comes into play).
Now, lets say you want to run your engine at 0.73 lambda for e85 and 0.78 for 93/meth. Stoich afr for e85 is 9.0:1, 93 is 14.7:1, and meth is 6.47:1. Dont forget our fuels are mixed! E85 is going to be (.85*9+.15*14.7)= 9.855 and 93/meth is (.2*6.47+.8*14.7)= 13.05.
So 0.73 lambda for e85 is going to be (.73*9.855)= 7.19:1
0.78 for 93/meth is (.78*13.05)=10.18.
0.78 for straight 93 is (.78*14.7)=11.45
AFR is air to fuel ratio, ie, the amount of air needed to completely burn 1 unit mass of fuel. So if we keep our airflow constant (just playing with fuel, remember?) then we are going to use [1- (7.19/10.18)]= 29.4% more fuel with e85 than 93/meth...but is that more energy available?
Just for comparisons sake our turbo moves 40kg of air (about 800hp worth).
Straight
[email protected] lambda (40/11.45) = 3.493kg of fuel for the air given.
93/
[email protected] lambda (40/10.18) = 3.929kg
[email protected] lambda (40/7.19) = 5.563kg
Using our energy content from earlier:
Straight 93 (3.493*46.4) = 162.08 MJ
93/meth (3.929*41.06) = 161.32 MJ
e85 (5.563*32.46) = 180.57 MJ
Keep in mind we are richer with the e85, at 0.78 (truly apples to apples), it would be 168.82 MJ.
So using straight 93 as the baseline
Straight 93 = 100%
93/meth = 99.5%
[email protected] = 104.2%
[email protected] = 111.4%
SSSSOOOO.....*based purely on the fuel consumption*, running e85 slightly richer in place of 93/meth will give you 12% more power everything else being equal.
The HUGE caveat to this is all things are NOT equal. Remember how we are injecting a lot more mass of e85? Well that fuel displaces air, so all the sudden you cant push in as much air because some of the volume is fuel, so you volumetric efficiency goes down. By volume e85 is displaces roughly 6% more volume than gasoline, so your gap just shortened by that much. E85 burns cooler than 93, so from a thermodynamic standpoint your engine is now a less efficient heat pump. Also e85 is harder to ignite, ie, you need a stronger ignition system, this is a parasitic loss on the engine, unless you dont run an alternator. The flame front speed of e85 is slower, so using the same timing map of 93 will not allow the engine to fully utilize the power stroke. There are many more things to consider, but this hits the high points.
