Abrasive
I say it with pictures
Here are some pics for you to contemplate. Appears to me to be totally feasible if you remove a small amount of material off of the edge of the LIM in six places around the L67 injector bosses on the heads. Probably would require less material to be removed than it looks in these pics since the LIM would be spaced up a bit more with the gaskets in place. Of course, I'm assuming you are using an N/A intake with a turbo setup as a SC is never going to mate to the N/A LIM.
The injector holes appear to be angled away from each other enough the injectors would not hit one another, but I don't have any injectors laying around to test that for sure. :th_winking: These pics have the LIM bolt holes lined up with the LIM bolt holes in the heads, so it is sitting right where it would be (minus gaskets) if you were to install it this way.
Good luck!
Good luck!
