    TIPS:
Dual Heated Seat Kit (97-03)
indygrandprix
Kit Adds a heater to your passenger seat.
Includes
-Dual Switch Plate (Looks OEM except for a slightly visible seam down the middle)
-One Heated Seat Switch For Passenger Side (Regular switch is used for drivers side)
-Heated Seat Switch Relay
-Heated Seat Switch Wiring
-Heated Seat Wiring
-OEM seat cover with heating elements or just 2 heating elements
NOTE: All wiring is plug and play. There is no soldering or cutting of wires required. To install you WILL need to remove the passenger side seat, the centre console, and pull up the passenger side carpet, unless you run the wiring above the carpet.
To install the Heating pad elements you will have 3 options.
Option1: Get a seat cover and sew them onto the bottom of it.
Option2: Actually remove the seat cover and replace it with an OEM seat cover that has elements sewn onto it (NOTE: There will be a couple holes on the console side of the seat since cover is originally from the drivers side but are not easily visible when seat is installed)
Option3: Actually remove the cover from your seat and install the elements under it. (Not recommended if you have never removed a seat cover before)
Options2&3 will give you a factory look and will last longer than Option1 since the elements are fixed in place and not moving around and pulling on the wires
If you chose option 2 I need to know the color if your interior and it is also and extra 30 dollars since it it not always easy to find good condition seat covers. (I do not send out seat covers that are cracked, torn, faded, stained or dry rotted)
100 dollars shipped.
Plus a 10 dollar core charge for your old switch plate
Plus 30 dollars if choosing option 2
(I have two available right now. More available in future)
Indianapolis, Indiana
I accept paypal only. Message me if interested. Do NOT reply to thread.
If you just want the stuff to make a drivers heated seat it would be 60. Unless you want the full covers. Then it would be 90. But no core fee for the switch plate
I suppose it would work but I do not have switches for 04+ so you'd have to cut a hole for it somewhere and I'm not sure how the element pads would feel under the seat.
I mean, I have 04+ Cloth seats in my 01 GTP.
You should have no problems. Only issue would be getting the seat covers off the 04+ Seats. I'm not sure how they are exactly put on or what it requires to remove them to put the heating elements in but I'd assume it's pretty comparable to the 97-03 seats.
where is that relay located in the car? I have heated seats in my '01 GT (factory on driver side, and my mother had Roman Chariot add the passenger side heated seat before she took delivery of the car from the dealership), but they quit working 2 years ago (I posted a thread on here and no one replied). I've checked fuses and wiring and all came back fine. but I did not know there was a relay involved... is this like this on all vehicles with heated seats?
