Scottydoggs
Killa Bee
those codes were low voltage or some bs. plugged in or not, should not set the light. my egr, rear o2 and purge solenoid are 100% gone, plugs just sit there doing nothing.
Have you tried plugging in the evap components to see if it shuts the light off? I always left the evap stuff plugged in and just set everything to now reporting.
some pcm's cross over, i got a 01 pcm in my 98 regal. with a 98 bin of course. you need the year of your car bin for it to run right.
all you can do is try, if it takes it will just take, if its not gonna work you get a warning that is not comparable.
theres a pcm compatibility list in that drop box folder. shows the cross over part #'s.
Oddly I remember someone having trouble with EGR codes/emissions not going green. hahahaha
