churchryan55
Hello everyone new to the site. Having problems with my 1999 grand prix se. about a week ago my car started flooding the motor with gas and the check engine light came on reading p0440 evap performance problem.I'll start the car in the morning and drive for about 10 minutes just fine then it will start flooding the motor, I can put it in neutral and shut the car off and restart the car and everything will be fine once again for about another 10 minutes and the problem will start all over again. I've cleaned the egr valve which seemed to be the problem from all the carbon build-up but was not, check the evap canister, its fine purge valve fine, vaccum line from in-take to pressure reg fine return lines fine. everything seems to be fine.I know a pretty good deal about cars but cant figure out what if anything the problem is. The only other thing I can think of is the pcm and its hard to believe that its bad. any help would be great thanks
