Grandprix202
Alright I have an 04gt2 and the power lock on rear driver side door won't work... Won't go up or down. All others do besides that one. Any suggestions? I'm guessing a good start is taking off the door panel
I had that recently. I changed out the lock mechanism and still had the same problem. Turned out to be a broken wire in the loom from the door to the body.
If it happens to be the lock actuator, it's one piece with lock mechanism. Not separate, at least on my car it was.
peal it off carefully, you want to press it back up there when your done inside the door. if it wont stick, rubber cement works.
