new2prix99
On my 99 Gt the driver info center is so dim I can't read it. My question is can I change a bulb to make it brighter or is there another way to make it brighter. Any help would be greatly appreciated
Yep..just pull off the dash bezel, the DIC is just held in by two push in clips, one on the left side and one on the right side. Remove the harness on the back of it. Then you need to take the cover off of the DIC. Its just got some prongs that hold it there. You'll see the little square cutouts on the outer cover. Take a little screw drive or whatever you can find and push those plastic prongs down, gently. When you remove the cover you'll see this.....So all I have to do is pull the dash trim remove the (dic) and change the bulbs? I don't have to mess with trying to rewire anything?
