Door lock issues
allg32
OK '00 GTP. all of my doors will lock with the fob or the door switch except for the drivers door. They will all unlock with the fob or the door switch. If I plug in the sensor that turns the radio off when I open the door then none of the locks will work with the fob or door switch. The horn will beep and you can here the click under the dash but nothing else happens. is it just a shorted wire? The car was wrecked when I bought it (drivers door post) and had to repair some wires that were damaged. I pulled the harness about halfway down to the drivers seat just to make sure I didn't miss anything. Everything else works so Im a little stumped.
