Door Ajar Switch Location In GP
02WGTP
Hello Im having a issue with I believe my door ajar switch. Cause when I open the drivers door the intrior lights do not turn on, and when I get out of the car the radio stays on til until I open the pass door. I have tried searching and even looked on shopkey5 with no luck on the location of the switch to replace it.
Thanks Mike
before you try to replace it try spraying the door latches with wd40
My grandmas ford ranger had a similar problem it wouldnt sense when the door was shut and would say door ajar, i found on a ranger forum that wd40 would fix it so i sprayed the latches with wd40 and it works like new now with no probs
I'm bumping because i need to find this damned switch...
did a search and got some info in chat box but couldn't find it...
1998 gtp sedan drivers side
