K Kraziee
Ok so I have an mps with a 3.5, 3.4, and 3.3 pulley. I'm using a gates 653 belt. According to zzp the maximum pulley to use for this belt is a 3.5 and so I'v been using this belt for awhile on my 3.4 press on before I got my mps so it's probably a little stretched out from use. It fits snug on the 3.5 and actually has some belt squeak when the engine is cold. When I put it on my 3.4 I'm logging at most around 11.5 psi, now when I put it on my 3.3 pulley I maxed out around 11.2 psi. The belt goes on like butter on the 3.3 so I'm thinking since it's been taken off and on so many times on larger pulley's it might have stretched causing it to be looser on the 3.3. Driving conditions where the same when logging with both pulley's around 80-85* weather, car fully warmed up, no knocking. So I'm thinking since it's tighter on the 3.4 that it's spinning the s/c quicker then with the 3.3. I'm thinking of trying the 650 belt to just see if it increases my boost because it doesn't make sense to me that a 3.4 would make more boost. Do you guy's have an opinion?
