GTP in RTP
PCV valve is on top held on by plate and 2 screws, I removed and replaced valve, did not see any o-rings on it ?:th_wtf:
CausesA code P0171 may mean that one or more of the following has happened:
•The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
•There could be a vacuum leak downstream of the MAF sensor.
Source: OBD-II Trouble Code: P0171 System Too Lean (Bank 1)
I would swap that remanufactured maf and see if that makes it go away.
Do your RPMs bounce?
Gasket was there, in good shape. Still chasing P0171 though.
Cleared the p0441 , previous owner had vacuum hoses routed wrong.
Had the vacuum port in the tb hooked directly to the vapor canister.
He then had the evap switch and soleniod hooked in a loop.
I unhooked the MAF, engine runs fairly smooth. Of course i got P0102 bad MAF signal. However the P0171 went away. Need to make it to JY to get another MAF to swap out. Does the P0171 going away mean it was the problem ? or is it just running in limp mode and the P0171 will come back even with another MAF ?
For the record, the PCV valve should have an oring on the "fat" part of it, as it fits down into the goofy plastic strainer.
Also, 97s have a mess of tubes all over so make sure none of them are broken or cracked.
DH is talking supercharged. But unless you lean over and look into the hole, you'll never see the strainer.
You can barely see it from below as well. See the thing in the hole
that's the strainer. Anyhow one o-ring on the bottom piece of the pcv and seal the top cover.
