Yes that's an aftermarket remote start sticker. For a Directed Electronics Product.
Sent from my Galaxy SIII on Tapatalk 2
I have a viper security/remote start system with that same sticker. Post a picture of your key fob
on the starters ive messed with its 3 pushs with the yellow(or whatever color you have) to start the car but it has to be awake first, like pressing the lock button first the press the yellow button 3 times and see what happens
What are the chances that this is a car alarm instead of a remote starter? The reason I ask, is I was in the car last night trying some programming methods I found on Google, plus some general pushing and mashing of buttons, and I found out that once I lock my car doors with the GM remote, (two quick pushes of lock button so the horn honks) if I then unlock the door manually (I was inside) and then open the door, or try to start the car, the horn goes off as it would in a normal car alarm. Going to try the two pushes thing and see what happens.
Pushing the lock button from the door then closing it activates the Factory alarm
Now that I remember, my brother, who is a mechanic told me to look for the modules, find the manual, and look for blown fuses, circuits, etc. (or as we always said in the military, find the brown spot, and you found your problem.Odds are it doesn't work. You said the guy told you it hasn't worked for a year. Odds are the tach isn't programmed or a hood pin is showing open (if Installed)
It's viper they have Lifetime warranty pull the brain and remotes send them into dei they'll send you a refurb
