disk break question
kjohnson
if i paint everything other then where the break pads run will the disks still be able to get ride of heat? i dont want them to overheat because of something that i did. im just wondering because im replacing all four disks. thanks for the help
thanks guys i figured that is what youd say i just wanted to make sure before i painted 120$ worth of disks. thanks again
the high temp paint that i got is good up to 500 degrees. that should be good enough shouldnt it? it is caliper paint so i figured it should be good
how long does a paint job normally last on these. i know there are factors like paint quality and enviorment but i live in iowa and i put three coats on. its a duiplacolor product if that helps. i just kind of want a gestament. thanks guys
