Disappearing Trans Fluid
tommythecat
Hello,
I just recently started having my car ('05 GT/105K) shift a little rougher in lower gears, usually only first to second. I checked my fluid level and saw that it was a little low. Once I added fluid the problem went away. A day later and the problem returned, checked fluid, a little low, added fluid, problem went away, no spots on driveway. Same thing happened the next day. No evidence of a leak anywhere. I have had to put in about 2 quarts over the last week or so to keep it running smooth. Everywhere I park there are no stains and the trans is dry on all external areas.
Anyone else experience this or know what may be causing it?
Thanks for any help,
Tom
check your radiator for the fluid to be in the coolant. the coolers break inside the rad.
if this is the case, stop driving it, as if coolant gets back into the trans its over johnny.
It may be only leaking when you're driving down the road. I would suspect cooling line seals at the transmission or input shaft seals.
Bingo, exactly what i am thinking.
This post brought to you by.....
