wstefan20
use grey rtv, no gasket.
Thanks Scotty! I might try that before i get a new throttle body. The warping is very very slight.
NICE. But id still tune it. but thats just me.
Nothing wrong with that. I put a Saginaw (Chev) p/s pump in my Bronco and ran DEXIII for years.Well, finally decided to check out the pump wine... someone had used transmission fluid instead of power steering fluid, so I had lots of fun changing that out... anyone else come across this?
that seal can chip and break when the balancer goes in, mine did. i think it was super old gasket kit i got.
if you popped a new balancer on and used the old seal, its shaft may not be 100% the same as the old one and the old seal will no longer seal.
id lean towards a damaged seal then. mine was fine until it warmed up, then pissed like a river.
**** ya impact on the big bolt then the balancer stuff falls right off, impact on boom boom done
