Difference in engine harness for 97 GTP vs 98 GTP
You should be able to post a picture if you upload it to photobucket. Then put the link to the IMG in your post.
If you look at the trans connector for a 60 and 65 trans, you can map the 7 wires from the 60 to the 65. From there, you'll have 5 left that are needed (on a trans with an external PNP switch). Then add those 5 wires to the pcm connector where they are missing.
