Mr D
DD--03 GTP 128K mi. RPOs L67 MN7 2WR69
1st, Automatic trans simply terrify me, so all help is greatly appreciated. I have convinced myself that my vibrations and clunks are from my differential and decided to grow a pair & do (Attempt) an on car replacement. I have done a good amount of reading and homework, and feel I understand about as much as I will from reading & pics.
I plan to buy parts from gmpartsgiant.com. They take a week to arrive with normal shipping, and thats what I can afford. & since this is my DD, I would like to be able to have all parts before I start. I use Illustration Key # when refering to parts so I don't get confused, because the key #s seem to be consistant even when name of parts & manufacturers part #s are not.
I am getting Diff Carrier Assembly (700)-$210.
I have NOT found a how-to specifically for on-car procedeure. My 1st concern is "Differential Carrier End Play". Is there a test, and what tools are required, for it on-car? Which leads into, there are 9 different sizes of Diff Carrier Thr Washers (714)??? Is this something to skip or is there something I should/can do about the Test and selecting the proper Selective Thrust Washer (714)?
Also, in general, are there other parts I should order, which would be accessable from on-car procedure, that should also be replaced? Such as:
Front Diff Carrier Sun Gear Shaft (689)-$70
Internal Gear Thrust Bearing (695)-$12
Front Diff Carrier Sun Gear (697)-$50
Front Diff Carrier Thrust Bearing (715)-$10
Thanks in advance.
Thanks in advance.
