DHP Powrtuner severity 66 error -fixable?
fst
recently got error 66 Database Error Unable to Init AC List whenever i open up the program the small error window comes up. is there a fix or how to repair this issue? this is even before connecting the powrtuner to the car. i am currently trying to just do some editing on my bin file. TIA
bill, what do you mean if i need another link for a dropbox? you mean a copy of the powrtuner software? i are confused lol.
Yeah I have been using it for 5 days. Yesterday I flashed for probably the 8th time and it was interrupted, then I went into recovery and it reflashed successfully. I then edited another file and tried to flash today, but had to do the same thing, going into recovery... Now it won't even open after several reinstalls
Sent from my SM-G935T using Tapatalk
No I didnt. But there were no issues for several flashes. I am still open to any ideas on how to fix the problem.... There has to be something else that corrupted which doesn't get uninstalled with powrtuners. I'll try uninstalling MDAC and . Net framework, as well as all other programs
if you didnt have dot net 1.1 installed it wont work at all. its the radio fuse. pull it then flash it. dhp dont like the 04 05 cars much, it can be a tad clitchy, why a off board is best. you bypass the cars BS and flash right to the pcm.
Alright I uninstalled everything, deleted the reg file, and reinstalled everything. Still getting the error
Alright guys I figured out the solution without just using a different laptop - you just gotta add a new user on ur laptop and use that user to open powrtuners.
Dude,
I wish you had known that was a solution 3 days ago... Running it as administrator also works. I don't know why it needed to be run as admin all of a sudden, but whatever, we're good now. 👌
