dhp help
Stock as far as I know.
Most of its life[ the first 100 thousand] was spent with its two other owners and 25,000 with me
also one other thing,when I read the pcm it had to manualy read it
Hmm. Could just be what it said, and unsupported OSID. If you post the bin it read, one of us can confirm it. Simplest solution if it isnt supported (likely due to it being an older and less common osid) would be to use a newer osid for your car. You can enter your vin at TIS and find all the osids supported. I likely can provide you with a sotkc copy of one of the osids it finds.
Thank you I have to look in the morning because it locks the bin file when i try to open it with a error message 73 or i could go outside now but i rather not get yelled at
vn-1g2wp52k8yf135628
by what i understand it has been reprogram so whats the next step
Hmm. If you could post the bin you read out, it would be appreciated. Likely a bin not mapped that could be added..
Anyway, your bin is likely cal/os id 9384045, which is not supported by the PowrTuner.
The newer cal/os id for your vin is 9389750. That one is supported. Check your PM for help with that.
