Denso Wideband?
Pure2sin
I have a PLX wideband that uses a Bosch sensor. I was looking for the cheapest place to find one and noticed they come on the Volkswagon Jettas from 99-05. After looking on Rockauto, I noticed that Denso makes a Wideband sensor that has the same connector as the Bosch.
Anyone ever tried one of these with their PLX or Innovate wideband controllers or will it not work?
Edit- I noticed that ACDelco makes one also. 2133894
Denso-
Part# 2345117
getimage.php
[TABLE="class: bdydesc"]
[TR]
[TD]OE Style[/TD]
[/TR]
[/TABLE]
[TABLE="class: bdytext"]
[TR]
[TD]
  • Double Protection Cover— Maintains proper unit temperature for quicker response times and protects the ceramic element against silicone and lead poisoning.
  • Aluminum-Oxide Trap Layer— Keeps silicone and lead outside the ceramic element through DENSO's exclusive design, preventing damage to the platinum electrode.
  • Stainless Steel Housing— Resists corrosion and contamination with a rugged, watertight body.
  • Porous PTFE Filter— Allows atmospheric oxygen to enter the sensor without permitting water or engine contaminants to seep into the casing.
[/TD]
[/TR]
[/TABLE]
Wouldn't it read the same considering it is made for a stock car? The Bosch sensor, ACdelco and Denso are all on Rockauto as the same sensor for the Volkswagon Jetta.
Just might have to try it.
