GreyGhost
The car has extremely hot air and the fan works as it should, but the problem is it is not defrosting the side windows. What it is allowing is for moisture to build up on the windows and then freeze after the car is shut off.
3 items in question are:
Water pump
Coolant
Heater Core
Is the heater core on these cars under the dash or engine side of the firewall?
Yes, it could us a flush. I have needed to add a bit of anti freeze/ water, but replaced the cap and that took care of that issue.
Anyone else ran across this issue? Had it in the past and that usually means a hole in the heater core, but with the water pump issues and purge issues that are listed haven't found anything where someone actually replaced the heater core.
Water pump
Coolant
Heater Core
