jdmgtp
Scenerio: I start my car up cold, back it out of a parking spot, put it in drive. If I give if the accelerator a moderate amount of gas it either slips until I let off the gas OR if I give it enough gas it slips and then bangs into gear. It only does it on the initial launch after I put it in gear. If I get up to speed and stop and do it again it launches just fine, no slipping or banging.
I just had the trans rebuild. It had this problem before it was rebuilt and I even told them this was going on. I know they replaced the boost valve and the pressure control solenoid. Any ideas what this could be?
no codes either.
no codes either.
