Cylinder Head Casting Numbers ?
J7319M
2000 Buick LeSabre w/ 3800 Series II V6.
Where can I find the casting number for the rear cylinder head ?
Please don't tell me I have to pull the rear valve cover. :th_depressed:
why would you need the casting #? not thats theres a ton of info to be had off it, iirc its just got the year on it. if you need a head, any 3800 na head will work.
Scottydoggs - I need the casting number to get the correct cylinder head, correct ?
GTPpower - I gotta pull the alternator and belt tensioner to get the rear valve cover off. :th_depressed:
Any cylinder head from basically 97-08 that was on a NA 3800 would bolt right on to your car.
Supercharged heads look different because the injector holes are cast into them.
you'll be taking it off to change the head. like stated, any n/a head will work. whats the back story here? why the head swap?
if it hydro locked the upper intake failed and leaked coolant into the cylinders and or oil as it always does.
How much time do you have ? I was changing the intake manifold gaskets when I got the bright idea to chase the bolt holes in the cylinder heads to clean them up. Usually that's not a bad idea if a person uses the correct size tap. The correct size tap in this case would be 5/16"-18. The tap that was used by the most idiotic person in the world was an 8mm X 1.25mm. So by time I started on the third hole, I finally realized that metal shavings are not supposed to be coming out of a threaded hole if it's just being chased. So now with 3 holes in the rear head severely damaged, I order a Time-Sert kit from Amazon. That would've worked fine if I was able to drill the holes at the correct angle. Two of them I got pretty close, but one was way off. So in my vested interest to punish myself for being so stupid, I'm going to replace the rear cylinder head.
oh lord, thats a bad story.
be best to hit up a junk yard and snag a head off any 3800 thats na. you can grab the front head thats easier to take off, same head.
you also need new head bolts.
and you'll want to watch some you tube vids on valve lapping. your gonna need to do that, when cars sit the valves get rusty and pitted up, sure it will run, but it could run even better if the valves all seal like they should.
I just want to find a head that's never been remanufactured. I want a head that's never had anyone attempt to repair any of the threads. I'm thinking a salvage yard is the only place to find that. Being as particular as I am, I'd go to a self pull yard and pull it myself. If I find a good one, I'll have it looked at by a machinist.
no one chases lim bolts in the heads, so those will be just fine, some times they are whole engines, some times they are part torn down, never know what your gonna find walking the lanes of cars.
Most of the time by time I get there, the entire engine and trans is gone. Hopefully this time I can get there there before the big parts giants get there.
Scottydoggs - do you happen to know the size of the lower intake manifold bolts ?
I know they're 5/16"-18 with a 3/8" hex flange head, but I don't know the length.
Where in the USA are you? I have a head from my old 00 GP GT motor (N/A Series II) that's good. Never been messed with just pulled it off my old motor. Shipping could be an issue though if you're too far out. Has around 150K on it but never had an issue with it.
Well, technically I have both from my original motor but the #1 cyl. ate a bolt and turned it into a 5 cyl. (don't ask, lol..) I never bothered to look at the valve on that head since I needed a new motor after that anyway so I don't know what shape it is in. I just yanked the motor and replaced it then later on I pulled everything off the old motor down to the shortblock so I could scrap it. I'll look for the good head tonight if you would like, just let me know. I can ship though UPS at my work but I can't imagine it being cheap.
That sounds real interesting FordMan. The salvage yard here charges $39.99 + $4.99 core charge. I haven't priced machine work yet. It would be nice if I found one that was so sweet, all it needed is cleaned up and new valve seals installed. Is there any chance you can snap a picture ? No damaged or repaired threads, correct ?
Its gonna cost you $40-50 either way more than likely. Machine work for what, clean it up and run it.
