Cylinder 5 misfire UPDATE Broken valve spring
Re: Cylinder 5 misfire UPDATE no pressure in cyl
So can I just change that one spring or will I need to do them all?
How does the spark plug from that cylinder look? Bent, broken, anything? If the spark if is fine then your piston is still there and points to valvetrain
yes you can just change the one spring, but do check the plug, if its damaged, you have bigger problems like stated above.
All the plugs are good. I need to go to the dealership tomorrow and get one. No autoparts stores around carry it in stock.
