How the #$@* do you get a crow bar in to get the axle out of the transmission. I can't find any leverage points...:th_angry2: Where exactly is the seal? Is it the lighter colored metal just inside the outer transmission cover?
Got the hub end axle out fine without doing the ball joint. Just can't get the transmission side.
I used a chain, about 10ft long with not so big links, not so small either, and was able to get it wrapped around near the end that goes inside the transmission. I wrapped the other end around a crow bar and gave it a good tug.
If you try to wrap it close to the hub, it will just pull the shaft out of the axle housing and you'll have a stub sticking out of the transmission, along with maybe some axle grease, if it still had some.
