Custom Fog Lights Only
stlmo_gtp
i was wondering if there is anyway to set it up so that you can have only your fogs and parking lamps on, but still be able to turn the headlights on when they are needed, every time it is dark out my headlights auto come on, so is there any way to do this kinda mod ?
On my 98 you pull the DRL fuse in the glove box. No more daytime running lights and no more auto on. You can cruise with the parking lamps and angel eyes on(my favorite). Some newer years it's not that easy though.
I have a '01 and its not that easy. If you pull the fuse on the driver side fuse box it kills the DRL's but if you pull the other fuse, I think on passenger side, the car goes crazy with this crazy chimming!!!! I found a way to counter that and still roll around with fogs and parking lights. You have to find it just rite between full on and parkings lights on your selector knob. Its like just past half way between the two and its awesome once you find it. Just dont be behind someone when your doing it and still trying to find the "sweet spot"
Hope that helps a bit
