Cruising and random unpredicted jerk
well i had already checked all my plugs and they all looked pretty good, i have pics if you'd like, so im only gonna do plugs last if it needs it, im putting the icm and coils on tomorrow and waiting on buying new plugs and wires, i might order stage 2 wires or whatever they are from zzp for like $60
If your buying wires get ac delco or the 100$ ones from zzp
Yea the reason why i say ac delcos are because i had autolite wires and within 4 months i tested the resistance and they were toast so i refunded them and went with the delcos. One of them were pretty much split in half.
I'm unsure what you do to wires Shayne.. :th_scratchhead: I put mine on and ... that's about it. Napa Beldens are also a lifetime warranty and a good wire. ZZP wires, I still have too much negative about how their quality went downhill and most sets were causing misfires. They were nearly as consistent as MSD coil packs.
where does this plug into....?
its safe to say every W body has at least one plug that goes to nowhere. i got at least one, maybe two.
but like i said, you see how dirty the seals are, the soft part, if it was plugged in that part would be clean.
