rperry435
Tracking down this problem. No codes. No adverse driving problems. Set cruise it works up until 60mph where it will set and shut off from a second to a few seconds later
Our TAC module is built inside the throttle body and it has a dedicated VSS wire from pcm to the throttle body. Tech 2 cruise history shut down shows "Wheel speed to high" after speaking with diagnostic Hotline that's because the TAC module sees a speed that's to high for cruise to set (not a wheel bearing issue like I originally thought, which all work perfect anyways)
With the tech2 unfortunately I cannot see the mph it's just not an option. I'm about to try a different throttle body to make sure it's not an issue internally.
Diagnostic Hotline also mentioned 2 cases of where the tune was a direct effect of an aftermarket tune. I'm pretty sure I had this issue before I started tuning with hptuners..
Anyone have any thoughts?
