Crow cams springs?
mkyota1
Has anyone had any problems running the crow cams 105# springs fron zzp? I did some research but only found a few people talking about them. Any info would be great.
Good springs, I'm running them at I think 1.74 installed height so that has the seat pressure at 130#. 10k without a problem.
I had a set but never used them because my heads came with 130# springs so i just used those. I sold the ones i had.
I've run Crow 105's and 130's and never had an issue. I've run both with JP single or RM single with no weird wear issue.
The chain itself is not the weak link, it's the dampner that usually takes a crap, most bump up the idle a hair to avoid the added wear.
