I wasn't sure what you were asking. I haven't seen an IFR table like yours. My guess is yours is showing compensation for when you are in boost, by the negative numbers. Only guessing, but makes sense since you would need a little more fuel flow to counter the positive pressure. I kinda wondered why the tables I looked at didn't have boost compensation shown.I have scan data and the guide only says and shows map kpa from 0 to 100. My ECU for my 04 shows negative values as well. It says to just make anything less than what ur cars sees the same number as the lowest one. So I did, I just didn't know why it shows negative kpa
My car only sees down to 50 kpa. So anything under 50 should be the same flow rate as 50, correct?
