Jeffintampa
Daughters car, she called me and told me it got alittle hot a few times on the way to work, She added water and got home. I looked and when motor was cool could not find any leakes from hoses, water pump etc. The water that was in the radiatior looked brown and alot of sticky brown crap was around neck to fill,
I drained the radiator, and put in a flush and filled with water, ran up to temp with a new cap and let set overnight.
Well this am was going to warm it up and drain the flush out, started the car, and noticed a drip when it got warm. Could not see anything from the top, or infrount of the tire. When I crawled behind the tire and looked up it was leaking right on the corner of the head in front. Now that I think about it I had to replace that motor mount right under it as it was rotted out, and the brown crap could of been a head gasket repair.
decent size leak. I dont see any evedence of water in the oil. Car is setting with the flush in it.
Your ideas would be welcome
Jeff
Jeff
