h0wl0ngcanitbe
Lifer
Yep. See where the oil pan on the engine meets the transmission? That black plastic cover with the 2 bolts in it (should be 10mm IIRC). Remove that and you will be able to see the bottom of the flywheel.
When I remove the transmission inspection plate I think thats what its called, is there a seal I need to look out for and or replace? Will clearly see where to clamp the vice grip or are there parts of the flywheel I dont want to touch. Im sure Ill know once I crack it open but im just trying to get as much knowledge as possible prior to tear down.
