Cranks but no start
3rdgen
I have an 07 gtp that cranks but wont start can hear fuel pump no spark no injector pulse. Tried swapping the icm and still won't start also tried swapping the crank sensor. Any ideas I am beginning to think its the pcm at this point?
If it cranks but no start then the fuel isn't igniting. Do you smell fuel? A bad fuel pressure regulator can cause this issue. Bad coil, fuses and electrical ground like fivefingers said too. Do you have any engine codes?
