USonuMabeaCh
So which will I be using to read knock, the aeroforce, or the dhp?
And where do I find 1.95 ratio rockers, lol.
Wow you have a xp cam ported heads and fsic and your kr rises if you go lower? Injectors are the same? Or you upgraded? Im running 2.8 no knock with the same cam headers and a gen v with ported heads..can't understand that onehere is my opinion: I have an XP cam, ported heads, a full size intercooler and am running a 3.25" pulley. my car has kr when I go smaller. you will not be able to just buy one pulley and call it good, unless you are will to settle with a 3.5". you could probably run a 3.25" pulley if you did the headers 1.9 rockers and a methanol injection, but again tuning will be required.
Lol!! But . does he have e85? Must have a vac leak or something.. Not tryna question it or put crap in the thread.. Just saying i cant see a cammed icooled car only running a 3.2.. Knocking at times... With ported heads^ the thing is..he didn't get his XP from me
Sent from my LG-D851 using Tapatalk
Oh ok.. Not tryna tlk s**t just tryna figure why all those mods you have and its not allowing you to drop pulleys and you have every knock killer for the motor other then e85 ...I have no idea what's wrong with it. I haven't been able to find a vac leak. did have an exhaust leak that is fixed now. I'm on 42 lb injectors and a northstar tb/maf. I'm planning a swap to 130 lb springs in the next couple months, so we will see what difference that makes. doing a double roller timing chain and a bigger harmonic balancer in the next month.
What type of intercooler?I understand. no offense taken. I am in the process of a custom turbo build, so I'm not real concerned about the big pulley.
Man ... I was thinking of grabbing one too!!! Hopefully u find the issuefull size phenolic
Im pretty sure i can drop to a 2.55 with tuning and that phenolic intercooler.. Along with the e85 that i have.. Im currently am on a 3.0 right now went up a size.. Id rather get the timing upped on in then to rag on it with 2.8.. If you ever think about selling the IC.. Im your guy lolwith that build you have, a phenolic intercooler would support a 2.6 pulley. I have a 2.6 and the snout machining tool and I would let them go pretty cheap. pm me if you are interested.
the phenolic works really well as far as I can tell. I put a temp gauge in the front mount heat exchanger, and it is stays at the lowest temp the sensor is calibrated for, 68 degrees F. I'm trying to decide if I care enough to know what the actual coolant temp is to buy an aeroforce coolant temp sensor kit, or just go with an air temp sensor in the lower intake manifold.
