The car has two stage fan control. Possibly there is an issue there. Also, make sure there is coolant in the bottle. If not, it will be slow to warm up. Here is the GM serv manual diagnosis for the fans. Lengthy, but this is what can be checked for the fans. The links will not work, so don't try to click on them.
Did you perform the Diagnostic System Check - Vehicle?
Go to
Step 2
Go to
Diagnostic System Check - Vehicle in Vehicle DTC Information
- <LI type=1>Install a scan tool. <LI type=1>Turn ON the ignition, with the engine OFF.
- With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to
Step 3
Go to
Step 4
Important:
A 3-second delay occurs before the powertrain control module (PCM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Go to
Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to
Step 12
- Important
Do NOT remove the 20-amp fused jumper wire connected during this step. Use a second 20-amp fused jumper wire while performing the following steps.
<LI type=1>Remove the fan 1 relay.
- Connect a 20-amp fused jumper between the battery positive switch side voltage circuit and the fan motor supply voltage circuit of the cooling fan 1 relay.
Do both cooling fans operate in low speed?
Go to
Step 22
Go to
Step 5
- <LI type=1>Disconnect the fan 2 relay.
- Connect the second 20-amp fused jumper between the cooling fan low reference circuit and the cooling fan motor supply voltage circuit of the fan 2 relay.
Go to
Step 23
Go to
Step 6
6
Connect the second 20-amp fused jumper between the battery positive voltage circuit and the cooling fan motor supply voltage circuit of the fan 2 relay.
Does the right cooling fan operate in high speed?
Go to
Step 9
Go to
Step 7
7
- <LI type=1>Install the fan 2 relay. <LI type=1>Disconnect the right cooling fan electrical connector.
- Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit to the ground circuit of the right cooling fan electrical connector.
Does the left cooling fan operate in high speed?
Go to
Step 25
Go to
Step 8
8
Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit of the right cooling fan electrical connector to a good ground.
Go to
Step 29
Go to
Step 30
9
- <LI type=1>Install the fan 2 relay. <LI type=1>Disconnect the left cooling fan electrical connector.
- Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit to the cooling fan low reference circuit of the left cooling fan electrical connector.
Go to
Step 26
Go to
Step 10
10
Connect the second 20-amp fused jumper wire from the coil side battery positive voltage circuit to the cooling fan low reference circuit of the cooling fan electrical connector.
Go to
Step 11
Go to
Step 31
11
Probe the battery positive voltage circuit on the switch side of the fan 1 relay with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
Go to
Step 27
Go to
Step 32
12
Is the right cooling fan operating properly in high speed?
Go to
Step 19
Go to
Step 13
13
- <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the fan 3 relay. <LI type=1>Turn ON the ignition, with the engine OFF. <LI type=1>Connect a test lamp between the high speed cooling fan relay control circuit and the battery positive voltage circuit on the coil side of the fan 3 relay.
- With a scan tool command the High Speed Fans ON and OFF.
Does the test lamp turn ON and OFF with each command?
Go to
Step 15
Go to
Step 14
14
Probe the battery positive voltage circuit on the coil side of the fan 3 relay with a test lamp that is connected to a good ground.
Go to
Step 34
Go to
Step 33
15
Install a 20-amp fused jumper between the battery positive voltage circuit on the switch side of the fan 3 relay and the cooling fan motor supply voltage circuit.
Go to
Step 24
Go to
Step 16
16
Probe the battery positive voltage circuit on the switch side of the fan 3 relay with a test lamp connected to a good ground.
Go to
Step 17
Go to
Step 33
17
- <LI type=1>With the 20-amp fused jumper still installed. <LI type=1>Disconnect the right cooling fan electrical connector.
- Connect a test lamp from the cooling fan motor supply voltage circuit to the ground circuit of the right cooling fan electrical connector.
Go to
Step 25
Go to
Step 18
18
Probe the cooling fan motor supply voltage circuit of the right cooling fan electrical connector with a test lamp that is connected to a good ground.
Go to
Step 29
Go to
Step 30
19
- <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the fan 2 relay. <LI type=1>Turn ON the ignition, with the engine OFF. <LI type=1>Connect a 20-amp fused jumper between the cooling fan low reference circuit and the ground circuit of the fan 2 relay.
- With a scan tool command the Fans High Speed ON and OFF.
Go to
Step 20
Go to
Step 28
20
- <LI type=1>Connect a test lamp between the high speed cooling fan relay control circuit of the fan 2 relay and the battery positive voltage circuit of the fan 2 relay.
Go to
Step 23
Go to
Step 21
Probe the battery positive voltage circuit of the fan 2 relay with a test lamp that is connected to a good ground.
Go to
Step 34
Go to
Step 33
22
Inspect for poor connections at the fan 1 relay. Refer to
Testing for Intermittent Conditions and Poor Connections and
Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to
Step 40
Go to
Step 35
23
Inspect for poor connections at the fan 2 relay. Refer to
Go to
Step 40
Go to
Step 36
24
Inspect for poor connections at the fan 3 relay. Refer to
Go to
Step 40
Go to
Step 37
25
Inspect for poor connections at the harness connector of the right cooling fan. Refer to
Go to
Step 40
Go to
Step 38
26
Inspect for poor connections at the harness connector of the left cooling fan. Refer to
Go to
Step 40
Go to
Step 39
27
Repair the left cooling fan motor supply voltage circuit for an open. Refer to
Wiring Repairs in Wiring Systems.
Is the repair complete?
Go to
Step 40
28
Repair the left cooling fan ground circuit for an open. Refer to
Go to
Step 40
29
Repair the right cooling fan ground circuit for an open. Refer to
Go to
Step 40
30
Repair the right cooling fan motor supply voltage circuit for an open. Refer to
Go to
Step 40
31
Repair the left cooling fan low reference circuit for a short to ground or an open. Refer to
Go to
Step 40
32
Repair the fan 1 relay battery positive voltage circuit for an open.
Go to
Step 40
33
Repair the battery positive voltage circuit for the fan 2 relay and fan 3 relay for an open.
Go to
Step 40
34
Repair the high speed cooling fan relay control circuit for an open.
Go to
Step 40
35
Replace the fan 1 relay.
Go to
Step 40
36
Replace the fan 2 relay.
Go to
Step 40
37
Replace the fan 3 relay.
Go to
Step 40
38
Replace the right cooling fan. Refer to
Cooling Fan Motor Replacement - Electric .
Go to
Step 40
39
Replace the left cooling fan. Refer to
Go to
Step 40
40
Operate the system in order to verify the repair.
Did you correct the condition?
