nakedredneck
My 02 gt will only turn on the fans when the temp reaches over 230. and then will only turn on the fans on high, they will not turn on at any other temp, or speed. i disconnected the temp sensor below the thermostat and the fans come on, on high as per the default safety setting. and they will come on with the a/c if it is turned on. read somewhere that there is a coolant temp sensor and a coolant temp switch. but i am unable to find any info on the coolant temp switch. and i am looking for ideas that might be wrong with the car.
thanks
thanks
