Hello, my wife has had this 05 GP w/ 3800 N/A since 06 w/ 13k mi. It now has between 160k and 170k. I have only had to do the water pump twice, coolant elbows twice, front struts, tensioner pulley bearing, serp. belt, plugs and wires, thermostat, and MAP sensor. It has also been Seafoamed a few times. I also flipped the motor mount dog bones. Last week I had to replace the rear calipers, pads, and rotors due to leaking where the e-brake attaches.
I had just done the second water pump and coolant flush (universal, not Dex) in the spring and since then it would have the occasional coolant smell when the engine is hot. I have also been noticing slight evidence of cross contamination in the coolant, but nothing bad so I have been monitoring it. It doesn't use any coolant, but has been using 1 qt. of oil every 3000 mi. since about 70k mi. She left today for the grocery store and I saw a new spot on the drive. When she got home I saw nice green coolant and some oil on the back side of the tranny pan and back side of the oil pan.
I then moved to under the hood to check on the water pump and coolant elbows and they look to be in good shape, but I found a pool of muddy oil and coolant sitting between two injectors on the back side of the motor on the pass. side. Just in that one pocket, and it looks like it spills out the back along the gap between the head and the valve cover and runs down. The source seems to be that bolt in there. I cleaned everything up and can't tell any better where the source is, but the bolt is tight and it doesn't seem to be coming down from the upper intake. The radiator and overflow res. definitely show evidence of cross contamination now, but nothing super alarming yet.
I don't understand what exactly failed to cause this, but I am assuming that I have lucked out and only need to replace the upper and lower intake manifold gaskets? I'm sure this is a pretty straight forward operation, but is there anything I should address while in there? Is there a good source for torque specs, or should I look for a factory service DVD on ebay? My buddy had issues with his intake gaskets on his 03 Malibu, but he ignored it and let the tank run dry, then drove it while overheating and paid to have new head gaskets put in along with new intake manifold, etc. About a week later the bottom end seized up from the coolant damaging the main bearings I assume. I don't want to go down the same route, doing the work myself or not.
Any opinions on my new issue? Thanks guys!
